Which ones have you used and are you happy enough to recommend one. I have a small block [ 350 ] stock other than manifold and carb. The stock distributor is still in it. And should I replace the coil while I'm at it. It looks original. Thanks for any response.
Sounds good. Is that a kit like the Pertronix or are we talking dist. Silly question because of the price but I've heard there is a space issue with a HEI distributor. I really don't know.
Skip White's is a small body HEI that will need an external coil.
557, David. I have the original coil do you think, in just your opinion, can I use the old coil or buy a new better coil.
USA1. I actually used on of the first Pertronix made on a Mustang many moons ago and it worked fine. But on this site I have had many myths and some old beliefs dispelled so I'm hoping for a lot of info so I can decide whats best for my old wagon. Thanks for the input.
The old coil will work with skip white's small body hei, but for about $13 he also sells the external coil to go with it. I didn't buy it initially and never tried it with the old coil, but eventually bought one anyway since it was inexpensive and would work better.
