1 - 3 of 3 Posts
Hi All new here and in need of help. I'll try to keep this brief and give as much info as I can. Info= Have a 55 Belair 355 engine W/142 Weiand supercharger. 605 Steering box. Question= Changing out vacuum boost power brakes to a hydroboost. purchased the CCP showstopper. replacing old Power steering pump with new pump W/O reservoir will be using a remote reservoir. Need help on what pressure pump I should be using because of the additional hydroboost. Any advise would be greatly appreciated.
Hydroboost does not require anything in the way of a special pump. A pump that works with a GM steering box is all that is required.
It is a very good idea to have two separate return lines in the reservoir to avoid back pressure in the hydroboost return line.
Discussion Starter #3
Awesome!!! Thank you Rick L, I will make sure and add a separate return from Hydroboost to reservoir.
1 - 3 of 3 Posts
