Things seem to be working good on the new engine, so I decided to put the air cleaner on. Whoops, the throttle linkage (stock) doesn't clear the bottom of the air filter. The air filter sits down about 2" below the top of the carb.
I see Jegs and I'm sure others sell a flat bottom 14" plate to use with your filter. Has anyone tried tat or can you recommend an air cleaner that will work with stock linkage. (Holley Street Avenger).
not alot of clearance under a `57 hood? i have a "weiand stealth" highrise manifold, and a 4 inch filter, flat base on mine. more room than ya think, i think.:hmmmm:
