try www.eastwood.com, might have some kind of crimping tool for that. :anim_25:
Fresh Air Vents. The 2 halves have apparently been smushed to get the seam to come apart, so wedgeing some wood blocks inside the tube to expand them would probably work. Some rivits would be OK if you have room to get a rivit in the small flange. Welding or brazeing would also work fine.Anyway, question is:
the pipes are apparently 2 pcs and seamed. after removing them for sandblasting I noticed one seam had separated from the crimp. someone then applied some type of putty or sealer to close the gap. I'm wondering if I should experiment with home-made wood blocks or something and try to force the 2 sides to meet, and then perhaps rivets to secure them?
You have to grind the spot welds off that hold the shaft to the flapper. Then you can pull the shaft, remove the flapper, grind or drill the rivits out that hold the 2 halves of the flapper together. I used close density foam to make a seal and bolted it back together. Weld or solder the shaft back on in the duck.Managed to get some hammer and dolly action to get the seam close and had just enough lip to accept small rivets--enough to keep it together anyway. Worse comes to worse I can lay a bead of silicone after paint is done. It's not a show car looking for 100 points, .so visually the seams are pretty much out of sight.
One more thing, does anybody have a trick for removing those flapper valves inside the vents? I lost sealing material after sanblasting.
sounds like a plan, thanksYou have to grind the spot welds off that hold the shaft to the flapper. Then you can pull the shaft, remove the flapper, grind or drill the rivits out that hold the 2 halves of the flapper together. I used close density foam to make a seal and bolted it back together. Weld or solder the shaft back on in the duck.
Just for info regarding these seals. This is the only place that I've found with repro fresh air duct flapper seals, if you don't make your own as acardon did.You have to grind the spot welds off that hold the shaft to the flapper. Then you can pull the shaft, remove the flapper, grind or drill the rivits out that hold the 2 halves of the flapper together. I used close density foam to make a seal and bolted it back together. Weld or solder the shaft back on in the duck.
