I have a stock 350 with ram horn exhaust. Alternator is mounted on the exhaust, where the generator would go. Is it possible to mount a late model power steering pump below the alternator? Not sure where to source the brackets. I would like to keep Alt & PS on the drivers side if possible and share the same belt...Thank you!
You need member Jalapeno he should see your post this evening and give you the 411.
Do you have stock front motor mounts? If so, you'll need a bracket that doubles as a left motor mount, several versions of that are made, some better than others. The PS pump won't be on the same belt as alt and WP, it will be on an additional pulley in front of the WP/alt belt, if you have a short WP.
