Sorry guys for all the questions ..... a quick question over the quarter window do put wind lace??? On a 2 door post 55??
No problem, if I understand what your asking. The only place the wind lace goes is around the door opening. The headliner is tacked to the strip over the quarter window then covered with the window trim molding. Ron
Ok I don't think so , but after I staple and put on trim molding I can see staples??
The staples that you see when the trim is on. Where are they? Above the quarter window trim or on the B pillar? Ron
You should not be able to see staples over the quarter window. You staple the headliner over the quarter window on the underside of the top edge.
Yes Ron over quarter window.... I thought the trim would cover over the tack strip section ??
I thought the trim would cover over the tack strip section ??[/QUOTE
It does. The tack strip should be facing down towards the floor board.
Facing down.......... do you have picture of that section to me it looks like it goes on the side????
