1 - 11 of 11 Posts
i was wondering does any one sell or know of other options other than the CARDBOARD door panels??? does any one sell a plastic pvc/ version? or similar... i tried masonite like peg board materal but after all was finished it was to thick and couldnot put handles on any help
There are other options, you just need to know the maximum thickness. I saw a guy use a marine style backing as he was concerned about the water.
The other thing is that the cardboard is stitched when you have the vinyl & material on the same panel.
It may pay to give Ciadella a call they may use other material.
A lot of upholstery shops use luan plywood, 1/8" thick. It's a quality plywood.
Another choice is plastic sheet in various materials. If you have a plastic supply house locally (most big cities do), they should have something for you.
I used the luane to make my door panels back in the 80's on my 57 2 dr wagon, I plan on doing the same on my 4 dr wagon in the future. works good, and you can paint or polyurethane back for water resistance.
big box store
I use a fiberglass material available at home improvement stores it is white grained on one side about 1/16th thick it is for wall covering/showers glue your material/padding to the smooth side works great strong and thin, got this idea from a custom upholster in the area that is what he users about $15.00 for a 4x8 sheet
I've been told to go the hobby stores and buy plastic sheeting, cut it to fit. Haven't done it myself, yet.
ABS plastic panels...about 1/8"...used to be a "roddoors" outlet R.W. & ABle...now closed....ABS panels and 3M dual lock fasteners works great!!
1 - 11 of 11 Posts
