More than likely, it was for a locator/clamp used when manufacturing the part. There may have been multiple suppliers and some used it, others didn't.
Just wondering, when you reinstall the lower a arms are you going to be using stock springs?In the process of rebuilding my control arms I noticed this dimple in the driver's side lower arm. It's the size of a hammer head but I doubt that any human could swing a hammer hard enough to leave a mark this deep in metal.I don't have the car here to see if anything on the driver's side needs clearance but I don't remember anything there. The passenger side doesn't have the dimple at all.
View attachment 386281 View attachment 386282
I made my own spring compressor / lower A arm installation tool using a length of threaded rod purchased at either Lowes or Home Depot. I made the bottom bracket out of heavy gauge steel. I also employed a safety back-up just in case things "let go". I believe I used rope looped a few times through the spring and tethering to the A arm and frame.Use a compressor spring, if you haven't got one there are places that hire them out, or you can make your own with threaded rod
The flanges provide most of the structural integrity. The dimple is in a meaningless area for that.could it also have been to add a little structural integrity to that section of the arm?
As was posted several times above, I was lucky enough to have a friend who owns a spring compressor which I used and it made the job easy.Just wondering, when you reinstall the lower a arms are you going to be using stock springs?
if so, what will be your method of compressing the coil spring and attaching the lower a arm?
just wondering, I'm planning on doing this job too.
I can't remember seeing that before but it must be more common then I realizeIn the process of rebuilding my control arms I noticed this dimple in the driver's side lower arm. It's the size of a hammer head but I doubt that any human could swing a hammer hard enough to leave a mark this deep in metal.I don't have the car here to see if anything on the driver's side needs clearance but I don't remember anything there. The passenger side doesn't have the dimple at all.
Do you think that since mine has one with and one without the dimple that the lower control arms were swapped at one time? The ball joints were still riveted into the uppers so I think those were originals.Dimple was put there for the mounting of the front stabilizer bar. Early ones even had a hole in it. I believe this was the plan, and the
maker of the control arm made them that way. By the time the cars were getting made there was a change to the way the mounting
was made, by then the tooling was done, and there was no reason to remove it.
