Guys, I am a little desperate here. I installed one of the ATO fuse panels that ecklers and others sell for the 55-57. I lost the paperwork and can't tell which fuses go where and how to add extra circuits, need a couple for the radio, tach, electric choke, and fuel pump. I have the sheet that states what amp fuse to use for certain circuits, but cant figure out what slot in the panel they are referring. Has anyone used this panel?
That's it! You are a life saver! Thank you thank you!
Have you used this panel? Do you know how I add power wires for the tach, stereo, and electric choke power to this panel?
Yep,
Everything you mentioned would go on the "ignition fused" labeled terminals on the pic. With the possible exception of the radio clock/mem wire which would be "battery fused".
Use a small screwdriver to open the spring loaded terminals, then stick the stripped wire in. Let go and you are done.
It's a pretty slick setup.
Thanks so much. I have just about got the entire dash re-done and rewired. this was really hanging me up.
