· Registered
Is there a way to save the back glass weatherstrip. i've removed a lot glass but had to cut the weatherstrip to get the glass out.i have a newer strip in there now realy dont wanit to cut it.i have a new back glass and want to install it.also do you need any kind sealer
· Registered
If the rubber is soft and pliable you should be able to get it out together with the glass. What was used to seal it may cause you problems. Good luck.
Jim
· Administrator
If it is 20yrs old i`d want ot replace it any way since it is probably hard just due to age, unless it has been kept in a climate controlled room.
