1 - 14 of 14 Posts
Just got a new AC Delco Ballast Resistor and it has a blue slash mark next to one of the terminals. What does this blue mark represent?:confused0006:
Maybe could mean it passed final inspection...
Can you post a photo?
ballast resistor w/ black dot 58-64 high performance
ballast resistor w/ blue stripe - 58-67 std performance 63-67 Vette without fuel injection 64-65 409 with hydraulic lifters
Don't ask me what the ohms rates are - I'll loose my coveted brownie point.
Hey jwmbishop, can this be used in a 55' stock? tryin to clean up engine compartment and the one installed is all crusty.
Yes the blue stripe is the std perf (most resistance) - I would run it with a High Perf coil - on a stock ign this will wake up the engine.
I would not use the std resistor on a cammed, high comp or dual point dist as you may not have enough spark available.
The blue striped resistor is 1.8 ohms and the black 0.2 ohms. However i have seen many aftermarket resistors with the blue stripe and when measured with an ohmeter have a wide variance on actual resistance. As others have stated the blue is for most std performance engines and the black for high performance ( i think 2x4's & fuelie). The lower resistance gives a hotter spark but will burn your points much quicker. To be sure which one you have regardless of color or markings check it with a meter.
ken 57
Thanks ken - just added the ohm ratings to my notebook!
1 - 14 of 14 Posts
