I bought one from eBay, it’s an older US made Napa pressure tester. Will do that, it arrived today.
I bought one from eBay, it’s an older US made Napa pressure tester. Will do that, it arrived today.I went to my local Advance auto parts store and they loaned me a cooling system pressure checker for free. Pinpointed the tiny leak I had on threaded fitting on my aluminum radiator. It would be the best way to try and isolated the leak from something.
Boy you've really had some bad luck lately. I'd say time to step back, take a breather and analyze what might be happening. Hopefully you'll find something minor. Good luck.One big positive step though, my fuel gauge is hooked up finally and working perfectly!
Just thinking about your situation, After a pressure test, before you pull the engine, why not pull the intake. then the heads off and see if it might be a gasket or something detectable with heads removed. You will pull the heads anyway, so why not try that 1st? Is it possible that an engine builder can test the block "in car" with head off? I know heads can be checked alone. Is it possible that the intake is not compatible with your heads (wrong angles)? Examining the head to intake gaskets and head gaskets might tell a story. Was the block "decked for flatness and heads planed? Just some thoughts.Boy you've really had some bad luck lately. I'd say time to step back, take a breather and analyze what might be happening. Hopefully you'll find something minor. Good luck.
not if you know how to tune. we made 430hp at the rear wheels on 87 octane with an ls2 @10.7 to 1Holley terminator X for the 5.3L but get the max version so you can run a 4L60e later, to gain OD.
Also CR will be 10.5:1 with 706 and flat tops. Even the valve reliefs won’t drop it much. Going to be ruff with 87 gas.
Even if its just a wonky gasket that caused it, I am going to re-gasket the whole thing, put the roller cam and lifters in, and have Roy put it on his break in stand. Here is a video of Roy breaking in a Pontiac 400 on his stand. He is the one that has done all of the machine work on all of my engines.It’s hard to believe the 327 is that messed up from sitting in your garage in AL! What a shame if it is. You are doing the right thing by having it checked out before you go any further.
Larry
An efficient 'mini-split is the only way to go.. less expensive, easier to install, and provides both heat and cool. A 1.5 T mini-split works great in my 1200 sf shop.......When you put heat in the shop, you might consider a "heat pump" that can give you AC as well (?)
Thanks! I forgot to mention the quarter panel skins are from the original body too. I've made a lot of progress, but it seems like I have just as far to go. I worked on other stuff today, but did get the front end ready to start ripping apart again. I drained the Dex coolant, will dump that. I'm thinking from the amount of water that the intake manifold may have cracked or the gasket let loose as its just about the specific amount of water that was in the oil that was in the water neck area. At least that's what I'm hoping.man, you have done yeoman’s work saving that car!
