Bertha’s loooooong saga
62156 Views 1102 Replies 55 Participants Last post by  ETriggs
Ok, I am putting this thread together so I have a record for everyone to see, suggest, comment, and critique. I have been to the first six Nationals, all without Bertha. Seventh was the lucky charm! I can't let this happen again, it feels too weird.
Here is the list of what I have remaining to do in the next 334 days. By June 24, 2022
1. Get car back home to Auburn. (Yes, it is in Defuniak Spring FL. right now.)
Sheetmetal Work
1. Buy new one piece floor and trunk floor and install
2. Install new rockers
3. Install and repair quarter panels
4. Repair rust / dents in roof
5. New hood
6. New Cowl
7. Repair dash (knee dent on pass side)
8. New trunk-to-bumper panel install and smooth into quarters
9. Align trunk lid
10. Prep and prime and paint
Glass
1. Rechrome side glass frames
2. Buy and install glass. (Vent windows done)
Wiring - install AAW kit I bought
  1. Engine
  2. Dash
  3. Interior
  4. Rear body
Drivetrain
1. Get motor running (already rebuilt)
2. Prep transmission (fluid and install filler tube)
3. Turn front brake rotors (they are new, but rusted a bit in the Florida humidity)
4. Buy and install gas tank (lines are already run)
5. Install steering column and wheel
6. Finish routing and hanging exhaust
Interior:
1. I already have a complete kit from Gina Ciadella (modified 670 trim). It is ready to install.
2. Install wipers, radio, etc. Just enough to make it fully functional
Trim
1. Buy new bumpers (front and rear) and install.
2. Finish polishing all of side trim. I have all of it, it just needs polishing.
3. Get new taillights and install
I think after this, it will be ready to drive to Nats. Not perfect, not complete, but drivable. That is what I want more than anything is for it to be drivable.
I am tossing around set on colors now, but will use a dark silver / gray metallic for the car with a dark blue metallic for trim Strato blue / white. I still have to decide on specific colors though. Paint is now a mix of the VW Strato Blue and Porsche Aetna Blue. I am sending a sample to Orion Automotive and it will be called "Bertha Blue"
Am I forgetting anything major? I have had this car for 10 15 years, I need to get it on the road!!! Finished!
1081 - 1100 of 1103 Posts
the only real cure is ceramic coating by a competent coater.
  • Like
Reactions: 1
Try this stuff to deal with the rust.
Spray, use a maroon scotchbrite. This stuff works pretty good. Rinse and wipe off, wax and grease remover, paint with VHT
  • Like
Reactions: 1
Yep, got some of that. It’s the best stuff I’ve used yet.
  • Like
Reactions: 1
I’ve tried several times to install the seat upholstery on the back seat and have it look good. I failed each time so a buddy of mine from the local car club recommended a place in Columbus, GA that does great work at a good price. Just dropped off the back seat to finally have Gina’s work of art installed. He will also redo the front seat for me. He is a younger guy and it’s a family run business, I should have it back a week from Friday.
  • Like
Reactions: 3
I need you to come visit for a week and build a fire under my butt LOL! You get things accomplished :ROFLMAO:
  • Like
Reactions: 1
It’s only taken 16 years for this fire to get lit…. Lol! It gets easier the closer you get to being done.
  • Like
  • Haha
Reactions: 2
I'm to the intimidating part---headliner and back glass and windshield---I'm skeered 😕
  • Like
Reactions: 1
Can i assume that your fix for the coolant leak is resolved? Hope so.
  • Like
Reactions: 1
So far, so good. My intake appears to have been not fully torqued down and that freeze popped the gasket loose. Runs well and I haven’t even tuned it yet.
  • Like
Reactions: 1
I’ve run the engine a few times now. Once I get rid of the pesky exhaust leak at the headers, set the timing, and make sure all is tuned, I think she will run like the wind. There is nothing leaking that I can tell so that is better than my 60 Bonneville at this point. I need to hook up my temp gauge and run her for a while. I do need to align the new alternator mount a bit better, it tossed the belt sideways once.
Hood sanded with 600 to get rid of all the orange peel and ready for some spot color where I had to fix the crease from the radiator cap. Then hopefully a glassy three coats of clear.
  • Like
Reactions: 2
Coat of color. Another coat after this flashes and then clear
  • Like
Reactions: 2
While the paint is curing, I’ve been working on the exhaust. I’ve replaced that driver side gasket and it still made noise. Then I let my hands wander feeling for anything odd. Valve cover was vibrating.
Found the problem. The valve cover was bass ackwards and the rocker arms were slightly rubbing the valve cover. Just enough to touch and leave a mark. I flipped it around and it purrs like a kitten. Not a single noise other than the 8 trumpet symphony. I’m still swapping out the exhaust gasket on the other side, then wipe it all down and finish the brake lines.
Exhaust gaskets in and all torqued. Running well, just need to tune the carb properly and set timing.
  • Like
Reactions: 2
Take pictures of the headliner install, that’s coming up on my list.
  • Haha
Reactions: 1
I guess another time another place. Helped everyone get their projects done and have my enclosed patio to rebuild and suddenly everyone has something to do now. So headliner is on hold and having to hire a guy to help me next week jack the roof and reframe the structure.
  • Like
  • Sad
Reactions: 2
No good deed goes unpunished,................gene
  • Like
Reactions: 5
Sooooo, while working on the brake MC and booster area, I managed to break off the cheap aluminum dipstick right at the block. That means I get to drop the pan and punch the cheap one out. Oh well, I have a chrome stock style one handy.
You might try threading a bolt into the broken tube then tapping or wiggling it out I've had that work seems like a 3/8 but can't remember it's been a long time ago.Might & I said might save pulling the pan.
  • Like
Reactions: 1
Will give that a shot. Thanks!
