I was down in Reno at Hot August Nights last weekend looking at a bunch of beautiful tri-5s. I would recommend the trip to any car buff.
At the swap meet there I purchased a rear leaf spring re-locating kit made by TCI to use on my 55. The intent was or is to lower the rear 2"s and be able to install wider tires. After the purchase I looked under probably 50 tri-5's at the show to see how they did their rear suspension. I saw mostly 2 to 3 inch blocks between the diff and spring and a few with 4 links and a few with the relocate kit like I bought. I am now wondering if it is worth the hassle to notch my frame for the kit.I would love some help on which way to go. Thanks in advance.
I did a kit on my '56 210. Primary reason was the rot that I had on the frame. I just got the chassis back together today. The kit will leave it at the stock height unless you use blocks. You will increase your room for a wider tire but not with out doing a mini tub to your wheel wells. You can see where the original spring perch located the spring.
Dave
it depends on what kit you get.I saw one kit that gave an option of different springs to adjust from a stock ride ::) Or if you already got a good pair of springs the blocks do a fine job:D
