Do most of you guys use polyurethane body mounts or do you go back with the rubber original style?
I am about to do some floor repair and I think I want to replace all the body mounts first and get the doors lined up a little better. They are not real bad, but they are not perfect.
Wayne
I use rubber. I think the poly will advetually squeek and I don't think I want to ever grease body mounts. :)
Rubber here. You occasionally hear about replacement rubber mounts deteriorating prematurely. But you also hear the same about pu.
I ordered a set of rubber body mounts that comes with 10 of the metal body shims. Is that usually enough to get the body adjusted properly. What I don't want to do is get the body shimming procedure started and then not have enough shims on hand and have to wait another week for more to be ordered.
Thanks,
Wayne
