One for the experts, no luck with anything similiar in the search option .
Six cylinder with a single throat YF Carter carby . The car would start but run very rich with black carbon out the tail pipe . If you start the car and NOT let it warm up enough then take off and stall (PG auto) you cannot restart the car, the carby would flood . Previously I would wait a day or two then the car would start :happy0065: Car stalled the other day BUT no luck in starting it this time, the motor sounds like it wants to fire up but just does not :banghead:. By the time I try it a couple of times theres a bad smell of fuel like in the past :scared0005:.
Since then I replaced all fuel from tank with fresh fuel and taken the carby apart, readjusted the float, new gasket set, clean etc thought that solved the problem but no luck.
I have spark etc, motor sounds like it wants to fire up but its like theres no detenation in the piston, any way I`m dumb founded, your help is needed :fahne19:
P.S I was going to replace leads, coil & plugs next.
O.K. D.S. you may have hit the nail on the head I removed and cleaned all plugs the ol`girl fired right up :congrats: I adjusted the carby so it now idles high in park, but when its in drive if I dont give it a bit more gas it will cut out. I`m thinking there may still be a problem with the carby :confused0006: at least it ran took it up the highway ran like a rocket, its the low revs at a stopsign in drive that worry me now any more suggestions as to the cause?
idles high in nutral and won't idle in drive - sounds like vacc leak, or idle mixture - sometimes the mixture screw gets rammed in (over tightened) and deformed - once this happens carb is really questionable as the seat in the body could be damaged - or (if lucky) just the screw itself
goes good with hard throttle, with bad partial throttle problem is in circuit transitioning - may be the enrichment circuit (not familiar with this specific one) or a vacc leak.
And my approach has always been to over correct the ignition first - never hurts to make sure you don't have something like a cracked distributor cap etc.
And HELLO friend down under - you have a beautiful country there - I spent 5 weeks and did not want to come home!
Angs1957, What i do and you might want to do is to put a manual choke on your carb. That way you know exactly what position the choke butterfly is in and where it runs the best.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Chevy Tri Five Forum
