Just another solution.The pictures were very good, I will use them . I would like to know how you welded the braces to door jams. Raybob
raybob i bolted everything that touches the car then welded and bolted the rest for i dont trust my weldsThe pictures were very good, I will use them . I would like to know how you welded the braces to door jams. Raybob
If a sedan your OK not bracing, but others by all means brace it.I'm getting ready to pull my body and put her on a rotisserie, is it necessary to brace? My floorpan is intact as is my roof. I just need to do some minor repairs on the bottom and want to paint the underside...I will probably pull the doors off.
Should I brace, or am I OK since the floor is intact?
Its a 2dr post hardtopIf a sedan your OK not bracing, but others by all means brace it.
