1 - 2 of 2 Posts
I need to remove the pedal assembly on a 55 wagon.
I've got all the bolts loose, gauge cluster and master cylinder off. I have also removed the two round threaded braces.
All is loose and flopping around really nice.
Since both pedals straddle the steering column, I dont see how this is going to come out without removing at least one of the pedals, maybe both.
I dont want to remove the stock steering box/column if I can help it.
Good time for a beer break and to ask for trifive opinions. :beer:
Thanks in advance.
Take the clutch rod and lever off the shaft at the pivot. Slide the clutch pedal to the left to pull the shaft out of the assy....
1 - 2 of 2 Posts
