I have a brand new brake system on my '55 210...front discs, rear drums, dual chamber master cylinder, stock ( new) brake lines. Does anyone have a totla for fluid ounces this system holds? I am going to use the new Wilwood DOT 5 fluid, and would like to purchase only the correct amount, as it ain't cheap!
Thanks!
Don't know the system capacity, but you could just start out with the 12 ounce bottle if you don't want alot of extra fluid. You will have some lose when you bleed the brakes. Not sure if 12 ounces will be enough. You can always buy more if you need it. Think the 12 ounce bottle is around $5. I would just buy the 32 ounce. With the 32 ounce, you'll know you will have enough.
