1957 Chevy Bel Air Convertible; ZZ4 w HEI ign; 700r4; 9" rear w/3:50 gears; pwr disc fr w drum rear
Hold on....I just realized this is oil pressure sending unit, not temp sensor.
I guess this copper line got moved around once too often in the past couple of months with dizzy replacement, MC, etc...it broke off at the manifold fitting tonight. Please see pictures. It's a SUN unit. Tube broke off right at 3/8" brass cap fitting at manifold. Pictures attached show manifold fitting stub, and cap.
Is the fitting base 2 pieces? (base into manifold & tube sits in base as compression fitting?) I can't get the center out (tube part) and don't want to mess up soft threads trying.
Maybe someone can shed some light on the easiest fix. I'm hoping I can leave threaded base in and just replace copper tube?
