55 Chevy. My speedo cable broke INSIDE of the speedometer assembly. (It was plastic tipped.) Obviously the new cable won't go in. Any ideas on how to get the broken piece out?
RIP 11/24/2021
:hello: hi blackburn and welcome. good to have you here. i think you will have to start by removing the whole instrument cluster. :anim_25:
Put a very small spot of super glue on the broken tip,stick it in the hole ,wait a minute then pull it out? Maybe?
Since it's plastic, I'd try drilling it out with a drill bit that is exactly the same size as the flats of the speedo connection without drilling out any metal. Then you can reach in with a probe and pull out the plastic remnants in the corners.
