1 - 11 of 11 Posts
I'm looking to get a set of 1956 California License Plates for my 1957 Chevy. I want to make them as correct as possible. Does anyone know the correct number sequence for 1957 in California? I have found all kinds of information but none that tell me what number sequence is correct for 1957. Any help from anyone out there is appriciated.
Trifive Calendar Editor
Supposedly each county had a stack of plates and handed them out as needed. Hence the numbers & letters were all over the place. -but they do fall in a range.
1955 Black Yellow plate
Black "55" on Grey background 1951 w/1955 tab
1956 Yellow Black plate starting with "A-G"
3 letter 3 number configuration for car. 1 letter 5 number configuration for truck
1957 Yellow Black plate starting with "D-O"
Black lettering on Red sticker 1956 w/1957 sticker. Sticker on rear plate only
I would guess that they started with AAA000. My 57 (in 1964) was CFA934. Different counties had different prefixes, you could tell where the car was from originally by it's prefix. I hope this helps or gets you on the right track. Dave
Holy smokes. This took about 3 minutes. Thank you all. Looks like I'll be looking for license plates that start anywhere between D - O.
Thank you all.
Trifive Facebook Admin
You will need a 57 red sticker on one for DMV to accept them. I got lucky on mine, as it was registered to 64 and when I (my wife) removed the newer stickers the original 57 one was still in great shape. Otherwise you need to also find one of them, usually go for around $100.00 each:cool:
Randy
Check ebay for a inspection sticker ,,if you have no luck,, check this guy out http://inspectionsticker.net i have found my original on ebay they do show up i use laminate on both sides and double face scotch tape and stick it to the glass and you can peel it off anytime and reaply it :anim_25:
I forgot to add i have bought 3 of these original stickers on ebay and have paid about 20 bucks each ,,so they are out there,,, but if you need it right away the repro guy does a nice job ---:anim_25:
We don't use those stickers in California.......... just the license plate tab.
Randy
1 - 11 of 11 Posts
