Hey everyone! Finally got around to having someone rebuild a 350 for me. Its already getting flat-top pistons installed. Just wondering what you would recommend for a cam for me. The cars still got the stock rear end(as far as i know), a 200-4r, and i'll be running 3-deuce.
Thanks everyone
Thanks everyone
WHAT HEADS YOU RUNNING? looking for compresssion ratio you're goin run
well i got 350 with 202s 10 to 1 compression edelbrock intake holley 670 street avenger and a 280 comp cam and iam very happy with the set up very lumpy cam but works fine, muncie 4 speed stock rear end. tha dang engine gets it on. i highly recommend the 280 comp cam. rick
try going to comp cams website and downloading their cam program. it asks all the important questions and gives several suggestions based on your input. i called comp 3 times and got 3 different opinions from their guys and everyone of them suggested a bigger cam than i thought was needed but the program was right on in my opinion.
I think a 280 is a bit big if you have stock gears and not a lot of compression. I'd drop back to a 274 or 268.
I think that's what the website is going to tell you too.
