1 - 14 of 14 Posts
I ordered some inner trunk patches and a mix up occured and I was sent these. Before I send them back I'd like to know where they go just in case I'd need them anyway.
Underneath your quarter window.....that patch panel goes down to the floor...I believe for a 2 door car.
Eugene
That is where they go. I made my own patches for my car but it would have been easier if I had bought them. If it was the suppliers mistake maybe they will cut you a deal on them if you have a need for them.
Tom
I'm sending them back monday and exchanging them for the parts I need.
Rustaddict...do you not have any rust in front of the rr wheelwells on the inner qtr vertical walls? I would be surprised if you dont.
Stand the piece up vertical (sitting on the surface with the 2 holes) and take a picture of the other side (side facing down currently) if you dont mind. That should confirm what you have and if you need it....if its the piece i think it is.
I hate to see you send it back if you need it.
Greg
Greg
That side I took the picture of looks good. I was suprised myself. The other side needs a little work, but the rust is minimal and looks like it'd be easier and cheaper to make a patch for... and a small part why they are going back is I just want what I ordered. Although if I did have a worse case of rust there I would keep them.
PS. Oldskoolsalt, your car is really looking good!
Here are some Pics of the patch I made and installed on my car. Before you send them back check your car very carefully in that area. I would be suprised if you do not find some rust in that area, mine did not look to bad until I blasted it and removed the floor. If you do not need to repair that area that would be great. Good luck.
Tom
Someone on here has information on these and where they can be bought. I thought I had saved it but couldn't find it.
Seems like a member here makes them but I can't recall whom it was.
1 - 14 of 14 Posts
