I actually did a search and found a thread by ClassicGary on this. It was never updated. I'm wanting the same thing as Gary. I want a 3/8 flared line to go in a round canister style fuel filter with no rubber hose connections. It would look very clean and stock looking. So far I've read that there used to be a filter like this for a mid 60s Vette but it's no longer available. I also found a thread that said an AC Delco GF90 filter will work with fittings screwed into the filter. I PMed Gary yesterday and thought I'd see what some others may know with this post.
The 88/89 up chevy pickups used a metal round cannister filter with flared metal ends to attach it. Look for one of those filters and see if that is what you are looking for.
1956 chevy 210 del rey sedan
you can also get the basic tpi camaro fuel filter and get adapters to go to AN.
I looked at alot of filters off the shelf at my local parts store. We tried mid 80s to 90s GM cars and trucks and they have an O-ring fitment. Most Fords had a push lock style.
The TBI/TPI filter recommended is a good choice. It has GM metric o-ring flares/seals though.
I'm going to use one on my car, converting it to 37º flare fittings. I bought some steel 37º flare to metric o-ring fittings from Summit to complete the deal.
If you're into bling, the case on this filter is stainless steel. It has some ink markings but those wipe right off with solvent.
Rick, do you have any part numbers or pics of the filter and fittings? I really like the idea of having an "off the shelf" filter. Did the fittings come with the O-rings?
