I hooked mine to the front side of the shifter lever on the column, that moved it away from the firewall so it didn’t rub. I also tweaked the lever on the column a bit so it would line up better with the transmission lever. 700R4 and get all the gear selections.
The slide adjustment on the trans lever makes the throw longer or shorter which effects the gear selection. You can also change trans lever clocking. I could have adjusted the slight rub I had but it was working and I was lazy
