1 - 3 of 3 Posts
Was going to get a eldelbrock manifold with a holley 600 and use a lokar throttle and cable to get around the original linkage set up.
Is this a ok way to go or is there better??
According to to the purchase info on the car it has a mild cam and a 2200 - 2500 stall convertor.
thanks for ur time
carb & intake
your choice of carb and intake sounds ok and should work well on your motor
i would like to make a suggestion that if you do not have a strong ignition system to go with this one of the bad deals is that increase of add on sometimes people forget to upgrade all of the parts detonation is bad for a motor by an upgrade this will make all of your parts work better together without damage
hope this helps you
thanks bob
1 - 3 of 3 Posts
