1 - 2 of 2 Posts
· Registered
Does anyone know if a 600 CFM Edelbrock carb will fit an original 265 4 barrel intake manifold?? It looks like the Edelbrock has holes that line up. Will the butterflies fit the intake without hitting?? Both carbs are still on engines that run, so I wanted to know for sure before I started tearing everything apart. I need to keep the Nomad running while the stock carb is being rebuilt. Thanks, Karl:confused0006:
· Registered
You will need a spacer plate.
1 - 2 of 2 Posts
