1 - 10 of 10 Posts
I have a Carter Carb form the 50's that I would like to ID. Is there a web site where I can go? I Would like to know what it is as I am tired of it on my shelf. Maybe someone could use it.
Thanks,
Jeffrey
parts
looks like a wcfb i have some part # give me the # on the top and the one on the main body i will see if i could help
dean
carb
hi that carb was used in the 283 220hp passenger and corvette it is listed as first and second design. and was used in the 57 model year cant tell if it was for a/t or s/t with out more # or brass tag hope this helps you.
dean
Discussion Starter #8 (Edited)
That helps a lot. No brass tag. Thank for the information!! Only other numbers are a # on the choke 170 499 then there are 11 or 12 patent#'s. I did find on the end that it says Carter WCFB
Jeffrey
carb
thats just the choke part # the only real way i know is with the brass tag it will tell the model # and build/ production date. a carb rebuild company may know more with those #
dean
1 - 10 of 10 Posts
