Got the speedo squared away, but the fuel guage is wack. full tank reads one half and half tank reads dead empty.
Suggestions?
Suggestions?
Do you have a stock 0-30 ohm sender?Got the speedo squared away, but the fuel guage is wack. full tank reads one half and half tank reads dead empty.
Suggestions?
yes new tank and sending unit.Do you have a stock 0-30 ohm sender?
I think I did that, but can't remember. good call on the brightnessThe back of the cluster has an adjuster to match to your sender. The instructions will tell you what position to use depending on sender.
also adjust the dimness of the instrument lights while you have it out
