I have found that Acetone works very effectively on removing overspray from rubber or vinyl it will dull the surfave but with the use of a vinyl/rubber spray it will shine right back up. Just to be sure you throughly mask any paint you don't want to remove then use a soft rag on your fingertip and dip it into the Acetone, it dries very quickly and won't leave a film like mineral spirits or paint thinners. DO NOT use Toulene, it will destroy rubber
Acetone won't harm the rubber or dry it out. I've used this method successfully on many rubber parts and pieces including tires that have gotten over spray on them.
Try it, if you have a piece of rubber say a piece of weather or window seal shoot some paint on it let it dry in the sun for several days or longer then try the Acetone. A painting contractor turned me on to this method several years ago when his guys failed to properly mask a couple of vinyl clad windows and they got enamel overspray on them when they were shooting the trim....it works. FWIW
