1 - 1 of 1 Posts
So probably over thinking this but what angle should the shaft bracket that holds bar that goes thru firewall be at? I,ve looked at manual but it doesn't really give angle. This is the splined shaft bracket that is under dash. The reason I,am asking is that po has installed new motor with newer bell housing.have built new z-bar adapter plate and that works great but have no more adjustment on lower clutch rod. Due to the fact it also has newer fork so had to cut and grind stock rod. It seems if I moved shaft forward a little it would give me some adjustment as clutch wears Thanks
1 - 1 of 1 Posts
