IS there supposed to be a piece of rubber on the inside of the U-shapped upper column mount ? (between the U mount and the column?) Getting ready to mock it up so I can cut a hole in the firewall and want to get it right..THANKS
When I took the ori. col. out of wife's 55 recently, it did have a piece of rubber top and bottom. It was kinda stiff (could be from age), and about an 1/8 inch thick.
Check the assembly manual.
If you have a piece of new radiator hose, it's a good material for a home made one.
PERFECT. Thank you all.
Mines a 55. I am AMAZED at how much different the 55-57's were. It's amazing the factory could re-design and gear up to build such a different car in such a short period and then build it for one year..
