For those of you who have a floor shifter but kept the original steering column, what did you do with the housing where the shift lever is installed? Did you leave it in place, blank it, shave it or remove and leave the spot empty?
Ooh. Good idea. Can I see a photo?On my '57 I left it on there and that is where I attached my tachometer.
I cut mine off with an air saw and cleaned it up with die grinder and paintedHow about cleaning off the levers on the lower end of the column that are visible in the engine compartment?
My comment was for OP but you slipped in before I hit save.I cut mine off with an air saw and cleaned it up with die grinder and painted
Manual or automatic transmission?How about cleaning off the levers on the lower end of the column that are visible in the engine compartment?
I have a 4-speed manual transmission. Removing the column shifter arm(s) may apply to an automatic transmission if using a floor shifter/console. Originally my car had a 265/PG trans. I also wanted a cleaned up look in engine compartment. Obviously what I did only applies if one does not need the shifter arm(s) and want to cleanup the column. That's why I posed it as a question in post #9, for a reader to consider.Manual or automatic transmission?
