1 - 2 of 2 Posts
Hi all, need to get some feedback on a column shifter.
I have a factory 56 automatic column and a 2004-R trans. I have used a Lokar #1800 linkage kit but never had any luck getting all gears from Park to 1st.
I now need another one, because I broke it. Don't ask :)
Thinking of the #1804 for GM columns, anyone use this and how did it work?
This is the one with a cable. Hoping to get all gears.
Want to keep the original column, what do you guys recommend?
Thanks for any suggestions
bowtie-trifive
Are you using the adjustabel transmission lever? The lever allows you to change the ratio of the column to transmission, so you can get more movement.
1 - 2 of 2 Posts
