1 - 3 of 3 Posts
Good luck, I haven't found anything that will not come up or off after time (after two tries on two different garage floors). Dave
You need a 2 part epoxy designed for concrete floors. Plus, the concrete needs to be etched for it to get a good bite. You can etch it with acid, by grinding or by shot-peening.
If you are going to do this yourself, I suggest you check out the flooring section over on the Garage Journal forum. There is lots of good information there.
Here's my floor right after doing my epoxy job:
Here's my writeup:
http://www.garagejournal.com/forum/showthread.php?t=26308
1 - 3 of 3 Posts
