· Registered
Hi guy's, I have a Dan Chuck kit for the core support (right in the middle). I has 2 shims that are stiff like a tire, 2 shims that are flexable rubber with slots in them and 3 metal plates. One plate go's on the bottom for sure as it has square holes for the carrage bolts. What order do the other parts go? Thanks :
· Registered
Large rubber one goes under the radiator support between it and the frame. Shims go between the frame and the rubber support as needed. (Probably no more that 3). Then one of the two metal ones below frame , then smaller rubber one, then other metal one , then the metal one with the tabs to lock the nuts. Jim
