CPP Offset Upper Control Arm Shafts Install
1823 Views 2 Replies 2 Participants Last post by  BeachVette6
Rebuilding the from end on my 55 vert and went to install a set of CPP offset upper control arm cross shafts but notice they hit the front of the upper mounting bracket and lack about an 1/8 of an inch from seating all the way against the mounting face where the shims go. Anyone else had this problem?
I do not believe it makes any difference witch way they go.
1 - 3 of 3 Posts
I had the same problem. I just put shims in it until I get it aligned. Hopefully, it'll need at least that much shimming.
I was thinking maybe I can just grind off the corners of the arms
1 - 3 of 3 Posts
