Had a problem with the fuel gauge on my newly acquired '55....It would stay at 1/3 full regardless of what was in the tank.....Took the wire off the sender, the gauge went to full....Grounded the sender wire, it went to empty.....This confirmed that the gauge and wiring were good and the sender was bad.
Ordered a new sender....When I went to replace the old one, I noticed it was a replacement and fairly new at that.....When I pulled it, I noticed that the float had several cracks and that was the true cause of the problem.
Moral of story....When replacing a sender unit, throw away the float and relace it with the F*&^ unit.....Part # COAZ9202B .....While your at it, ditch the rubber gasket, and get the cork one from Greg Coleman....He has an ad at CT.....Also use screws with copper washers and tighten them in a star pattern.
