1 - 17 of 17 Posts
What year of chevy crossmember would fit in a 55? i do have one under my car(homemade) .i want one with with a curved for more exhaust clearance
67-74 I know works somewhere around 75 or 76 they got wider and would have to be trimmed. 68-74 Nova is also good.
I run a 4 speed and got my cross member from C&P in Pa. They are a Tri-five parts vendor and sell the correct Camaro cross member with the mounting bkts. Around a hundred bucks if memory serves me. You can drill holes and bolt on the bkts or weld them in place.
Don
when mounting the trans crossmember, does it go at the top of the framerail or bottom of it. vertically speaking
Not sure I totally understand your question.....However, you want to mount it so the engine is 4* down in the rear.
was just wondering were it mounts. seen some car that mount on top, some on bottom. i have one of the aftermarket kits with crossmember and motor mounts
1 - 17 of 17 Posts
