1 - 10 of 10 Posts
Calling on all experienced painters..... Last night i masked off my dash area. After several coats of primer, sanding up to 600 grit, it looked ready for some paint, oh and the last coat was a primer sealer, then a light scuff and i set up for the next paint step.
I seem to have perfected the art of painting orange peel... It just comes natural to me.... I didnt worry too much during the priming because i knew I'd be sanding it anyway, but was really hoping for as smooth a laydown of the paint.
I painted three coats of dupont Centari pitch black, single stage acrylic enamal. I started with a dusting coat , let that sit for 8 to ten minutes, then layed down covering coats... 10 minutes between each coat.
Now for the questions..... I was able to squirt not a bad coat according to my standards, but it has orange peel for sure..... Is that normal?... Do i get rid or the orange peel by sanding with 1500 and 2000 and then buffing and polishing?... How long do i need to wait before it can be sanded?... And if i decide to paint a clear over top, how long do i need to wait to do that?
The guy at the paint store said if it was a single stage urethane the. I needed to wait 30 days.... Is acrylic enamal the same waiting period?
Thanks in advance
Gil
Thanks in advance
Gil
Did you use any hardener in the acrylic enamel?
Yes, hardener and reducer in the 4-1-1 ratio.... As indicated on the can....
Gil
You can try, but on a dash it's going to be easy to cut through the whole paint layer on the edges and corners.
You need to wait before taking the paint back down. Try a finger nail test...if your finger nail leaves an impression in the paint after applying medium pressure...it's too soft.
Main reason for orange peel is RH. Need to have a dry day or location. Don't paint if its raining out...may blush too.
you have to put down a full first coat! when you put down a light first coat you have set the pattern for the following coats .
One other piece of advise...since its a small area, a work light may be enough to heat and dry the paint if you can secure the lamp over the dash. Doesn't need to get hot...warm (100f) is good:anim_25:
Thanks for the advice guys, I am off to scout camp for the week tomorrow, the paint should be good and hard by the time i get back next weekend, i will check it the. With the fingernail test..... I'm not trying to go crazy on it, the dash trim covers about a third and its the top that I'm most interested in.
I'll give it a try and if it looks good .... Then I'll post some pics.... There are way too many guys on here that would laugh otherwise..... All i can say is ... I did it, sometimes thats a good thing and sometimes .....well......
1 - 10 of 10 Posts
