I used a 3/8" spot weld cutter. It drills through the first layer of sheet metal, around the spot weld, so you don't damage the layer or the brace that you want to save.
http://www.blairequipment.com/ The very bestI used a 3/8" spot weld cutter. It drills through the first layer of sheet metal, around the spot weld, so you don't damage the layer or the brace that you want to save.
How much do these cost?I used a 3/8" spot weld cutter. It drills through the first layer of sheet metal, around the spot weld, so you don't damage the layer or the brace that you want to save.
