I have purchase a 67 chevy non power dual master cylinder for my 1957 chevy. I ran the brake lines. Tried to bleed and it doesn't look like the standard 1957 brake rod is long enough to work the master cyliner and help here?
did you bolt it on the bottom 2 bolts.i put a 69 vette mc on mine and it went in like the original on the bottom bolts
You may need to adjust where the rod connects to your brake pedal arm to change the length of stroke.
