RIP 02-03-2022
I can't get the thumbnails to open....but....the only dumb question is the one you won't ask.....somebody will be able to help.....plus you might have the wrong ones....:anim_25:
:gba:
bowtie-trifive
RIP: 10-27-2018
Tod, David is correct. If I might add, IF you have cast iron manifolds you will not need the wider bracket. That adapts the headers to give you a place to mount the F bracket. You will probably have to add a washer or two to make the alternator fit tightly between the F bracket. If you have a straight generator support bracket you will have to replace it with a curved one and you will need a longer belt than the stock generator.
