1 - 11 of 11 Posts
Anybody put one of these under their stock-spring trifive?
Any issues or tips to know about? If you have pictures, please post.
Thanks.
Update: ***i just did a search on "Bronco" and found a good bit of info. It seems to be a great swap into a stock car****
No tips I must admit. Putting this rear in one of your cars?
Thanks.
Maybe.... If I can get our good friend in Forney to sell it to me. :)
Just got my chassis back from powder coating and I'm gonna start slamming it together as soon as it gets below 90 degrees.....
Cool. Will follow this tread. Ran across one of the rears myself recently. Did not buy it but might depending on what you find out.
Thanks.
I have a 58" 9" out of an old Bronco. Been running it since I built the car in 1990. Only slight caution is the probable 28 spline axles vs much stronger 31 spline. One huge advantage to this combo is the fact it's 2" or so narrower than a stocker, giving more room for a deep-dish wheel. I'm running a 3 1/2" back spacing on a 15X8 wheel wrapped with 255/60/15's.. it's a really tight fit, but the springs are in their stock location, and I have no tubs...
Mike,
That looks great. Thanks for the feedback.
BTW, What style housing ends does your Bronco rear end have?
mike what year of bronco rear end will i be looking for to fit
in my 55 are they possi
Yes is was a limited slip. Then a few years ago I changed the entire center-3rd member with a complete unit from Speedway Motors, again limited slip (I also changed from 3.70 to 3.50 ratio). I got the complete rear assembly from a friend, so, I don't know for sure which Bronco it came out of, but, I believe the early "small" Bronco's are all the same. Another option is a 58 or so T-Bird, wagon etc... they are all narrower than the stock trifive.
I'll swap it for the 69!
Not sure what you mean by housing ends. (?)
No problem. Looks like most of them have early style big bearing housing ends.
Haha!
We're still negotiating so I don't have it yet and don't have room for it, either.
1 - 11 of 11 Posts
