1 - 3 of 3 Posts
Is anyone using this set up?
http://www.classicchevy.com/assets/pdf/classicchevy/08-505.pdf
I'm not sure I've got room for the master cylinder because of my wiring harness - but it sure would look clean. An added bonus for me is that I don't have to worry about heat from my fenderwell headers cooking a firewall mounted master cylinder.
Hi, i installed the kit with a richmond 5-speed last winter..have about 600 miles on the setup. bleeding the hydralic throwout was a pain but the setup has worked flawless and gave me no trouble:)
Discussion Starter #3
Thank you for the info. I really like the hydraulic throw out bearing with this kit. It makes sense to me to replace the front trans retainer - it just seems like a better set up.
Now to figure out if the wiring harness will clear the master cylinder under the dash...
1 - 3 of 3 Posts
