anybody use this??? it has tiny pins and doesn't seem to fit right ---I have door weather stripping and the pins are a lot bigger and I was wondering should the trunk be the same these are really hard to get in and the w/s doesn't lay down at all
ecklers part # 13-14
but the clips are very thin and hard to put in the holes plus the w/s itself doesn't really conform well to the 57's lid
Leave the w/s out in the sun, get it softened up so it is easy to conform around the trunk lid.
If your holes are too big you can get larger push in replacement plastic holders, some guys put 3M sealant to help the rubber stick to the lid better.
ok i got a diff trunk w/s and it fits just fine except on the corners---it seems the
channel on the w/s wont open enough on the corners all else goes in pretty good any ideas? I cant close the truck
