1 - 10 of 10 Posts
1957 Bel Air sport sedan
My new Performer EPS 2703 intake just came in the door. I will get it on my 265 this weekend. Has anyone made this swap and if so, anything to look out for?
Thanks.
sorry eldon, im not familiar with that intake, so the only thing i can say is make sure it has a place for your oil fill pipe. also, the smaller the engine is, the easyer it is to install to big of a cam, intake, carb. you have to keep the intake runners pretty small to keep the fuel air charge moving quickly enough, otherwise the engine gets soggy at low speed. a 350 might see a certain cam, intake, carb setup as just right and be happy with it, but a 265 is going to see the same setup as bigger.
Thanks Phil. It comes with the filler pipe hole already drilled and a chrome pipe and cap. I am getting an Edelbrock 600 carb with electric choke. The cam is barely hotter than stock, called an RV cam. The only issue I have found at this point is where to drill and tap the oil filter return line. As was suggested by a member, I am going to clean it and clear coat it to keep as much of the grease out of the pores.
Thanks guys!
eldon, that oil galley is just above the timing cover for the supply line and the return line can dump back into the crankcase most anyware. i know you didnt ask this, but the filter doesnt work like a normal filter. that is its just a part time filter, not a full flow. the more flow thru the filter the lower your oil preasure will be. one of the lines or fittings on those were origanaly very restrictive. when i first bought my 56 it had very low oil preasure on the 235. the filter had hoses on it. someone had replaced the hoses and had used the wrong one. i found out from a old dude at a auto parts house and he got me the right hose. the fitting on the hose had a tiny hole in it, and sure enough my oil preasure came up!
Lloyd, did you use the original braket? It looks like the original bracket was added on to the rams horn exhaust. Thanks for those photos!
Phil, with it being a part-time filter, what is the change interval for the filter/oil? I am assuming the 3-5k miles.
Eldon. Not fair to ask a 64 yr old what he did it 1978:confused: Seriously, can't remember. First thing I did in 78 when I got it.
Don;'t hold me to it but I think I only replaced the long upper lever that adjusts.
eldon, i tryed to look up the oil filter change interval but couldnt find it. i think the filters were options. i would just change it when changing oil to keep the dirty oil out of my fresh change.
the alt bracket is from any small block with a short waterpump. like a 67 283 even early pickups
Thanks Phil! Lloyd, I can remember what I was doing in 78, you can't? :D :D I was in Kindergarten!
Now to finish getting my brake lines routed before I get beat senseless. :D :D
1 - 10 of 10 Posts
