i'm going to put an electric cooling fan on,got an aluminum down flow radiator,going to add a/c some day?any suggestions on a brand?to get or not to get?better to push or pull? i live in south Mo. gets hot and humid here!! thanks for any suggestions!!
Puller fans work better.
If you have the radiator mounted in the 6cyl position
the dual 11" spal fan/shroud unit fits well be aware its noisy though, also a ford taurus fan fits and is cheap from a salvage yard.
When buying fans if they make a high cfm claim and the amp draw is low comapred to similar size/cfm fans , the fans performance is probably exaggerated
Regards, Robert
Hi brad, the puller is definatley the way to go..id look at the Spal or Maradyne fans as they are better quality..the cheap Zirgo fans ( china)..well i had the motors burnout on three of them under warrenty before i got smart.Wire it through a relay cause the current draw is to much for straight through a switch..mine is wired with a temp switch in the cylinder head..on at 176..off at 166 degree's. Coolcraft makes a reasonable cost custom aluminumn shroud for whatever size you choose..dual 10-11" or a single 16" to fit your rad:)
i use a two speed fan out of a 6 cyl taurus. it has a built in shroud that works well with the downflow aluminum radiator i am using. it REALLY brings the temperature down when the fan kicks in.
thanks!!! thats one sweet 57 you have there!!!awsome
I just installed a 16 inch electric cooling fan that I bought from Skip White in Tenn. It has ball bearings and is guaranteed for life according to Skip. It's a 15 Amp fan motor . Runs at 2400 or 2500 watts. I installed a 25 amp fuse in the line from the battery to the relay for the fan. I am using the fan as a pusher mounted in front of the radiator. (no room for it behind the radiator as it is 3.5 inches deep) and I have a v/8 radiator and radiator mounted behind support. Works great and no shroud. I have installed a circ. pump honeywell thermostat to control it as I am in the HVAC business. I have tested it with a digital thermometer and my engine keeps a temp. of 190-180 at idle with no shroud. I haven't tested it on the road yet as my car is under restoration. Jim
member
Did you mean 2400 or 2500 CFM??? If so, I find it hard to believe that you can move 2400 CFM of air with a 15A motor.
The dual spal fans take 25A and they are about 2750 CFM. Usually CFM correlates with amperage. I have a dual 12" Derale fan that supposedly moves 4000 CFM and takes 44A (two 265W Bosch motors).
Sorry about that! It's actually 200 Watt and true cfm rating is 2500. 14 amps to start it and runs at 7-8 amps. Note: has ball bearings and not cheap sleeve bearings. Jim
member
I'm very skeptical that you can get anywhere near 2500 CFM with a 7-8 amp fan, even on that's 14 amps. Here's a 16" SPAL fan that takes 22 Amps (~265W @ 12V) to get 2470 CFM and they're supposed to be some of the best out there.
http://www.a1electric.com/spal/specs/30102082.pdf
As I mentioned, the Spal dual 11" fans move 2780 CFM with 25 amps (~300W @ 12V). Both of those fans are around 110 CFM/Amp. You have to put energy into the motor to move the air.
My guess is you'll have a lot higher current than you think if it's really a 2500 CFM fan. ;)
