1 - 14 of 14 Posts
· Registered
I am using epoxy primer fo the first time and its not working well. It is going on too thick and balling up sandpaper after 72 hours of drying. I is UP230G from Summit. Thinking about reducing the next batch. Is this a good plan?
· Administrator
1957 Bel Air sport sedan
The epoxy primer I’m using says to wait quite a while to sand. I leave the parts out in the sun to bake a while. How warm is it where you’re priming?
· Stainless Trim Restoration
Most epoxy primers are not intended to be sanded. There are hybrid ones that you can. Adding reducer will make it flow better but will not
change the way it dries or sands. If sanding is needed usually it is just a light sand and wet sanding is used. I don't like it done this way.
Usually if you need to do sanding, a urethane 2K primer should be applied over the epoxy during the window that it can be. You need to know
what the maker recommends for this.
Mikey
  • Like
Reactions: ETriggs
· Registered
It does say in the product description at Summit that the product is sandable. But given that it's a private label product I doubt if you'll find out any more than that.
SPI (Southern Polyurethanes) is one of the only sandable epoxy primers that's advertised as such and used that way. Even SPI says to use a urethane high build primer if you need material build up.
On the other hand, some well known epoxy primers like PPG DPLF are not really sandable and say so on their product sheets. DPLF is meant to be overcoated without sanding if within its time window. Beyond the time window, you scuff it with Scotchbirte or 220 grit on a DA before you spray over it.
· Registered
I have used it. You can recoat without sanding for up to 4 days @70 deg F. It will eventually dry enough to sand. I add about 10% Urethane-Grade Reducer and it flows better.
· Registered
I know with PPG epoxy you reduce it with acetone, up to 10%. If you do that, it sprays out nice. You have to wait about 4-5 days before sanding, if you absolutely have or want to. Sand it using very light pressure. Let the paper cut. If you apply pressure, it will just gum up the paper. Ideally, spray it on bare metal, then top coat with a good filler primer and sand that.
· Premium Member
I had a bad regulator on the gun removed it and it and added a touch of reducer flowed great, now I have runs to contend with. I do not think this is a good winter product.
In general, you shouldn't be spraying epoxy primer when the air temperature is less than 60 degrees.
From my experience on my '57 build, Nason Full-Poxy wet sands nicely.
· Registered
Reducing epoxy also reduces the adhesion, and the recoat window, it should only be reduced when used as a sealer. Best to check with the manufacturer because there are many ways to make epoxy.
1 - 14 of 14 Posts
